- Aug 10, 2019
- 2,556
- 5
- 0
Seems like there are too many options, as always, but I'm looking for some realworld advice—and to add options to my list that I'm not aware of. The Wadia outputs 50 wpc at 8ohms, and 75 into 4. I've heard from a few people that current can be just as important, and it's noted that the Wadia puts out strong, good current. Anyway...
I'm currently using a pair of Dynaudio Audeince 42s. I do love my Dyns, so a logical upgrade would be to the Dynaudio Excite x12. Seems like that has gotten a lot of great attention as being a reference point for options below $2,000, as long as you like the Dyn sound. Also, it's also a nomimal 6 ohm speaker, not 4, as Dynaudio states, so that should help with the Wadia.
So, my short list (without hearing most of them, as dealers are far off.)
1. Dynaudio Excite x12
2. ProAc Tablette Anniversary
I hear from a dealer they can be driven with modest, well designed amps. They don't need a tone of power.
3. Sonus Faber
Concerned about the sheer small size of the mid/bass driver, as I won't be using a sub.
4. Nola Boxer
I feel the Wadia provies good power to A42s well at upper-mid to loud volumes, and am looking for more detail at low to mid volumes. I am open to other benefits and surpirses as well!
After speakeing with Dynaudio direct, I ruled out the Focus line, as when Wadia and Dynaudio did a few shows together, they felt it wasn't a good match—which is why they stuck with the Excite series.
So, any thoughts?
Thanks!
3. Sonus Faber
4. Nola Boxer
So, any thoughts?
Thanks!
