Monitor Audio Bronze Subwoofer Audition
vpacalypse
151
With a budget of between £400-£500. What is the best subwoofer to intergrate into this system?
Currently the system stands as MonitorAudio front & rears...dali ikon centre...& denon 2311.
I've seen Tannoy Ts1201 for sale at £420( however retails at £600)...(this is also the only subwoofer ive seen with a reasonable discount. Another i'm thinking would be the B&W ASW610 goes for £499...(but what hifi have retailed it at £450?)
I'm not aware of any other deals or subwoofers atm.
What would be a good subwoofer to intergrate with a max budget of £500... looking for good qual mostly though value such as the ts1201 would also be good.
I couldn't afford the 610 so didn't demo it, but in a contest between the MA BR sub and the REL T3, I went with the REL. Works nicely with monitor audio stuff and the high level input is great for music. The T3 is still available with £200 off if you don't mind white.
http://www.audioaffair.co.uk/REL-T3-Subwoofer/product_1989
As PH said you can get a good performing sub for less than your budget. I would definitely think about using any spare cash to get a centre to match your Monitor Audio fronts
The ASW610 is class for it's price (I used to own one) keep your eye out on www.hifix.co.uk they usually have good ex-demo deals on subwoofers.
