Monitor Audio BR5
Yes indeed they do have rear ports, i have mine 35cm from the rear wall with no problems whatsoever!!!!
[quote user="yorkydave"]
Im struggling to get 20cm. Will that be too close???
[/quote]
Probably a bit...but with port bungs, 20cm should be far enough away.
MA recommend placing them 20cm away from the wall as a starting point and then trial-ing from there, so 20cm may be fine.........
If not they are supplied with foam bungs for this problem.
