Mid priced (up to £2,500) projectors
I'm looking to buy a projector around the £2,000 mark for a 6.5 foot screen, viewing distance 13 feet. I recently auditioned the Infocus IN82, and an ex demo Sim2 D80. I now realise that I suffer very badly from the rainbow effect - I found it incredibly distracting, even on the D80. As DLP is therefore not an option, does anyone have any views on good PJ's for my budget - I'm currently thining of the Panasonic PT AE2000, but before finding a dealer, does anyone else have anything they have used and can recommend. Main viewing is Freesat HD, with some upscaled DVD (will upgrade to Bluray soon!).
The Panasonic is an Excellent Projector, what i have seen anyway for the money. you can get yourself a good deal as well if you shop around, check out the reviews as well W.H.F has a review on this model.
The Panasonic PT-AE2000E is indeed the pick of non-DLP at that price point (go higher and the exceptional JVC DILA models come into play), but it's about to be replaced by the PT-AE3000E, which may be even better. We're planning to test it very soon...
Or a Sanyo Z-2000 which I've had for a week as of today. 70" screen 1.0 gain screen, 9-10ft viewing distance, white and a bit smaller than the Panasonics, and deathly silent which really makes a difference as it's above our heads. £1200. bargain.
R
How are you getting on with the Sanyo Z-2000? What is your main viewing content, and are you pleased with how it performs? Any major gripes?
