Hi all.
Does anybody know if it is possible to import CD metadata when you rip via Media Monkey and MM cannot find the CD on it's database.
I have many classical discs that iTunes can tag from the Gracenote DB but MM can't from it's database. I want to import to FLAC format which of course iTunes does not support.
Also had a look at the trial version of J.River media centre software with the same problem as Media Monkey.
