MC
plastic penguin
[quote user="JohnDuncan"]Cambridge 640p - bargain..........
Next worthwhile step up is a Dino, in my experience.[/quote]
JD, I know you highly recommend the Cambridge 640P. Would it give me a serious upgrade on my in-built phono stage? I have the A65 +
gpi
23
IMO no, you would need to step up to the Dino or equivalent mid-range phono amp.
John Duncan
2,031
15
19,695
I think so, yes. Arcam do some of the best built-in phono stages, undoubtedly, but the Cambridge is class A, dual mono, low noise, MM/MC, cool blue light - the works.
It's the best component I have, performance/price-wise, but it will depend on your table - you wouldn't hear much difference with a Debut and an OM5, for example, but I wouldn't be getting worried about it holding things back until I have my Gyro/Kontrapunkt B combo..........
plastic penguin
[quote user="JohnDuncan"]I think so, yes. Arcam do some of the best built-in phono stages, undoubtedly, but the Cambridge is class A, dual mono, low noise, MM/MC, cool blue light - the works.
It's the best component I have, performance/price-wise, but it will depend on your table - you wouldn't hear much difference with a Debut and an OM5, for example, but I wouldn't be getting worried about it holding things back until I have my Gyro/Kontrapunkt B combo..........[/quote]
Yeah, fair enough. My table is project Xpression 1 with a Clearaudio Classic Wood Cartridge.
John Duncan
2,031
15
19,695
Which deserves a separate phono stage, right enough - though I suppose the question then is whether the A65+ is transparent enough to show the difference, and on that front gpi might be right......
You could borrow one or buy one for 40 quid off ebay, cos you'll get that back if it doesn't make any difference
plastic penguin
As I will be upgrading the amp at some point, it seems worth investing in one anyway. And I've found spare set of interconnects, Cambridge Studio Ref, that I bought from Richer a good few moons ago.
I can't smile, because the icons have legged it! : - )
plastic penguin
My five year old daughter started using the word a few weeks ago. I subsequently asked the teachers and they said that most of the little'uns were saying it.
I turned up a page in the dictionary & nothing listed. Eventually found it on google & it means "something to be admired, good or attractive" so on and so forth.
I've just realized I'm almost a centurian.
John Duncan
2,031
15
19,695
And as a primare owner....................I'd buy the Cambridge and save the money for a Kontrapunkt
Apart from anything, have you seen the R20?!?!?!?
ASK THE COMMUNITY
