Marantz SR4001 AV. Can you Bi-amp with this amplifier?
nsr1200
Hi
I have recently got back into the Hi-Fi state of mind and purchased the following:
Marantz SR4001 AV
Gale Silver Monitors
Cambridge Audio Symphony 400 speaker cable
I tend to prefer a two speaker setup compared to a full 5.1 or 7.1 setup. The reason I have opted for the AV is to enhance my FreeSat HD and Apple TV experience and can therefore connect everything up via HDMI and have a more pleasing experience.
The Gale Silver Audio Monitors have the option for bi-wiring.
Instead of bi-wiring I would like to know if the Marantz SR4001 AV will have the ability to bi-amp?
Would I be right in thinking that I can connect up the Output Front A and B speakers terminals on the unit to the relevant terminals on the speakers?
Thanks in advance.
Crossie
58
If you only want 2 ch then you would do much better to get a stereo amp than an AV receiver. Use the extra money to get something better than the Gale's. If you specify your overall budget I am sure you will get lots of suggestions. Bi-wiring is a minor side issue do not get hung up on it, better to get the basics right first, then tweak later.
Cheers :)
chelstondave
23
I think that the OP has already bought the marantz. Looking at the manual online I don't think that this one can bi-amp which is usually done by re-assigning the surround back outputs
