Marantz PM7000N low pass filter
kramer2020
84
72
10,620
Daft question, but if I do not have a subwoofer connected to my Marantz PM7000N what frequency should the amps low pass filter be set to?
My speakers are Q Acoustics 3030i's
Would be surprised if it makes a difference. Most of the time this is about low passing the signal send to the sub not high passing the signal send to the speakers. But you can try. Run a sine sweep e.g. 30-200 Hz with the low pass set to 120 and again with the low pass set to 40. If it makes a difference, stick to 40. If not, this setting is irrelevant as you don't use a sub.
