Marantz pm6005 amp
bellyshere
7
I have a Marantz PM6005 amp along with an old Pioneer DV668AV universal player. My Marantz amp isn't meant to be able to manage DTS. However, when i play some dts cds i have they play. I just get static through the optical connection but they play when i switch to cd analog connection.
matthewpiano
299
95
18,970
The Pioneer universal player is converting the DTS to a normal stereo signal when you output it to the amp using analogue connections, so the Marantz really isn't handling DTS - the Pioneer is. When you use the digital connection, then you are asking the Marantz's internal DAC to handle the DTS, which it can't do hence the static noise.
ASK THE COMMUNITY
