Marantz pm6003 or rotel ra04 se floorstanders that would pair
emcc_3
59
11
hi just wondering if anyone could recommend floorstanding speakers for these two amps have listened to the pm6003 with wharfdale diamond 10.4 anybody now of any suggestions which would be a better match for these my maxium budget would be £500 nfor speakers.
Monitor Audio BX5 or possibly newer Kefs. It's a tricky one because both will excel with different speakers. This is the perfect scenario to audition and the dealer will recommend based on your budget and musical preference.
Hey. I have a Marantz CD6003 and PM6003 that I use in conjunction with a pair of Monitor Audio BR5s (now replaced with the better BX5s) that sound absolutely brilliant together once they're run in. Their only downfall, and I think you may find this with any floorstander to be honest, is that due to the lower power rating of the amp it sounds best when you give it a bit of juice!
It's certainly worth a listen, and the new BX5s fall (just) within your £500 budget.
Hope that's of use.
JLH
emcc_3:hi just wondering if anyone could recommend floorstanding speakers for these two amps have listened to the pm6003 with wharfdale diamond 10.4 anybody now of any suggestions which would be a better match for these my maxium budget would be £500 nfor speakers.
Hi emcc_3
Monitor Audio's superb new BX5's are worth considering. If you haven't already done so then as an alternative amplifier Yamaha's new A-S500 is also worth serious consideration. Imo the A-S500 offers a clear step up in performance over the PM6003 and the RA-04SE.
All the best
Rick @ Musicraft
justlikeheaven:
Hope that's of use.
JLH
i find the same with this setup but the wharfedale 9.1 , you have to turn it up due to the low power rating of the amp . i would choose something with a 8ohm rating if possible .
Along with the Monitor Audio BX5's, try the Acoustic Energy Neo V2 3's. Either of the amplifiers you mention will work very well with them.
Although you could pick up a pair of BR5's, which will allow you a little more budget for your amplifier. Speakers like power
Would the NAD 326 bee be a better fit for these speakers? Its just that i could demo these at peter tyson in carlisle
