Choucas said:hi,
I have a Marantz pm 6003 and CD 6003 set up .
Would the KEFs fit in with this system? I have approximately £500 to spend on new speakers.
Thanks,
Graham
FrankHarveyHiFi said:Hi Graham KEF used the 6003 pairing at the dealer launch of the Q Series to demonstrate the Q00's and Q300's. They've also used this combination at many hi-fi shows since, and we've done many demos in store of the same and similar combinations too. With the Marantz warmed up properly, the system works extremely well together, possessing a synergy very few budget components are able to compete with.
Beware of rear ported speakers if you're going to use them on wall brackets.
Choucas said:Hi, Rick,
Living in Guernsey, I'm pretty limited to what systems I can try out! I went for the Marantz because a) they were very well recommended by What HiFi and b) we have a local dealer.
The system resides in a lounge which has usual soft furnishings in a room roughly 7m x 4m. Current speakerswhich are housed on wall brackets, are Acoustic Energy Aegis Ones. I have Black Rhodium speaker cables which have to run through the ceiling, so can be up to 10 m lengths.
I listen to mainly rock and blues, although the system is used by my other half to listen to her music which is mainly female vocalists such as Katie Melua, Norah Jones etc
I have heard the KEFs with a Marantz system demo'ed at my local store and they seemed fine , but I can't have a home demo! I am looking for speakers which will be an upgrade on what I have and be compatible with my system. Because of space constraints, I am looking to use the wall brackets again, which are spaced about 5m apart. Other speakers I would probably have to order from the UK without hearing them, so advice is keenly sought!
Many thanks, Graham
I thought the KEFs sounded fine, with good bass and detailed mid and top ranges. The amp was a Marantz 8003, so I wasn't quite comparing like with like. ( The dealer then connected up a set of Spendors, which were something else!)
I currently have no issues with the AEs, but was looking for a significant upgrade to the system and was wondering whether the KEFs would give me that?
Graham
Choucas said:Thanks, David,
Your reply was very helpful - as ever!
Graham
FrankHarveyHiFi said:It was either the Marantz 7003 or 8003 that KEF used for their Q500 and Q700's, so yes, I would say that it seems the whole range works well together. You could also look at the XQ30 too, which have certain benefits over the Q Series. Some come up at good prices every now and again. KEF's main competition is the MA RX6, but I wouldn't say these have the same synergy with the Marantz equipment, but will take more punishment, so if you're into D&B, or something else demanding, it might be worth checking them out. You could also try the Tannoy Revolution DC6T's too - I can't see why they wouldn't work well with the Marantz.
Thanks for your comments - they have helped me considerably!![]()
Graham
I think the Spendors were the SA1s. Very good - but expensive!
I only know of one dealer who stocks KEFs and Spendors, although others can obtain most makes from the UK. This does make auditioning them virtually impossible before you buy!
I am leaning towards the KEFs because I liked them at audition, but do wonder if I would really see a significant improvement over the Aegis Ones?
Cheers,
Graham
Choucas said:Good advice, Rick - and saved some cash for the moment!!
All the best,
Graham
Zax89swe said:What about yamaha as500 paired with q300? Seems from the reviews that the amp got better sound and more juice then marantz pm6003 and where I live even cheaper? even though the marantz looks better id would put the other things first if its true.
Zax89swe said:Hi Rick!, and Frank harvey.
No I have no speakers or amplifier right now. As "cd player" I have a computer soundcard with Cirrius Logic CS4832 Dac with changed opamp.
Im listen much to aggresive movie soundtracks but also sometimes artists like Enya and acoustic music.
I will mainly listen to it alone and for now in a smaller room (wooden like) 2-3m behind a desk with a small monitor there the listening position will be. I will have the speakers on the desk at start until I got stativs.
I would like to get big detailed and some dynamic sound, some thrilling, neutral and that handles vocals well, I want the bass to be punchy with some weight. Got two systempicks in mind, the first is more in line with my budget and second one is more expensive, will the first system be good choice as well?
Monitor Audio BX2 - Yamaha a-s500
Kef q300 - Marantz pm6003
Thanks for helping me, Jesper.
