Marantz 7005 AV amp
jarra
24
Mine sounds a little underpowered. In order to get a good cinematic sound I need the volume turned up to 75. It goes from 0 - 99. To be honest I thought it would rattle the room at 60.
99 is quite loud. You'd be surprised how much more power will spill from the 7005 if you turned it up. Don't be scared - as long as the amplifier and speakers have been well matched, you'll be fine to turn it up. Most volume controls aren't linear, so 50 wouldn't be half way - more like 70, or even more.
Can you change it to run from infinite up to 0dB? If so, it'll usually run over to +15dB or something, and you'll be fine driving it at 0dB.
