Mains Cable for Roksan Kandy K2
Would like to seek some advise as regards to mains cable.
I just bought my Roksan Kandy K2 and would like to enhance the sound quality by replacing the mains cable with a better one.
I got no budget in mind yet, but based on review i was wondering whether Chord Company SuperScreen mains cable would be the suitable one, seems value for money.
I was recommended by my dealer, Ecosse The Big Orange. read the review, seems good also.
Need advise and help as i got no experience with Mains cable.
Thanks in advance 🙂
Chord Powerchord is very good too, in my opinion.
I have a superscreen , which i now use for the tv, after hearing the powerchords.......
1 metre lengths can be for for £60 too, (RRP £120-130)....
I'm located outside UK, can only get the 1.5 meters from my side. anyone got experience with The Big Orange?
Where can i find mains cable for my NAD C545BEE? It seems different from Roksan's mains.
Hi dennisk. I use the Chord Superscreen power cable with my Roksan K2, it really had a great impact on the overall sound. Not heard any of the other mains cables you mention though
really? i have a superscreen, it's made not a jot of difference on my amp or dac.
i would try something with a money back guarantee, that way if it does nothing for you...
Yah, thats funny - I could definitely tell when I upgraded my mains cable. As you say, I think trying before you buy (or with a money back guarantee) is the best way.
I just bought the Ecosse The Big Orange from my dealer as managed to get it at bargain price. S$210 (GBP 94) for 2 pcs of 1-metre One for Roksan Kandy K2 and one for NAD 545B EE
I can hear the difference after using the Ecosse The Big Orange power cable, but i can say the difference is not really that big. Vocal and music sounded warmer.
Craig M.:
I'm not suprised, seeing the great kit you have on the "your system" forum.
Very good quality components should have better/bigger transformers in them, hence they are less sensetive for mains noise and cords, not completely though. I didn't try any Chord powercord but i tried many others, the only one that made a difference (not night and day) was a Wireworld Aurora and Electra bronze, didn't try the Electra silver or gold, they are way to expensive. But anyway, i shouldn't use freebi cords, the wires in the walls are better and thicker then that.
