As per my system below I have just moved over to a computer-based source for my hi-fi. I'm still waiting for the Mac to arrive, during which time I'm using my old HP laptop to suss out a few things, one of which is which type of file format to go for. I have ordered the Mac with a big enough HDD to rip everything as uncompressed AIFF files and still have reasonable expansion room for the future. Quality is paramount, hence I was looking at AIFFs. However some comments I've seen from other folks here suggest that there would be no difference between Apple Lossless files and uncompressed formats such as AIFF or WAV.
Based on my own (fairly limited) experiments comparing the same tracks using AL and AIFF, I can't tell any difference, but if there is a benefit to using uncompressed files, even just a theoretical one, then I will use AIFF rather than be left with a nagging doubt!
Thoughts? Obviously if there is absolutely no difference then I will rip to Apple Lossless files!
Also, as a slight aside, am I right in thinking that when streaming music to an Airport Express the computer unpacks/decodes whatever codec is used to store the music and streams it to the AE as PCM - e.g. the amount of data being streamed is the same regardless of whether the original file was a 128kbps MP3 or an AIFF?
