Womaz said:iQ Speakers said:Well the problem is what is the definition of streamer? Must it have a DAC? I think it should and in which case it's all about the quality of the analogue output stage. And in the case of lower resolution source up sampling ability. Matt can you bring that test forward 4 months?
As I have found out some do and some dont. I had similar thoughts , like if no DAC how can the streamer alone significantly alter the SQ. read so much over last week or so and the general impression I get is that it can..........just from what I have read
I like to think of it as, Streamers with DACs and Streamers without, rather than getting bogged down in semantics...what matters is the SQ.
I suspect there are inherent advantges by keeping control of the process, by having it in the one box. Areas which I believe effect sound quality are:
- Power supply. There was a noticeable improvement to the Linn DS range with the introduction of the Dynamik power supply.
- Clocking/Removal of jitter
- Sampling. Upsampling/Oversampling/No Sampling. Linn use their own custom-designed up-sampling engine.
- Isolation of internal components through internal layout /case design, which is particularly noticeable in the KDS.
