Looking to replace my 25+ yr old PYE Hi-Fi bits of it keep dying
PhilT
6
The market is flooded by old products and out of date reviews neither of which seem to have been created in the last year or so not even Which?
I would be very grateful some advice or recommendations please on a bit of kit that has
FM, DAB & DAB+ radio with preset capability
a CD player that can read mp3 CDs I've made,
usb port that can read mp3 fies on a stick
and that I could use bluetooth or wireless headphones with.
A remote control
A clear display that shows album and track names would be a deal breaker.
and decent sound
and anything else would just be a superflous plus. well overkill really I dont need it to connect to my phone and probably not the internet
I dont need a turntable or cassette player . I sold all of those when I was broke.
Budget.. up to £300 I think but we'll see what people suggest.
jjbomber
Best bet is Currys, who will have a range of JVC and Panasonic units that do most of that. Not many have a bluetooth output, so you may need something with a headphone output that you can attach a Bluetooth sender too.
ClarkNovember
62
41
18,570
Do you have speakers already? If so the Denon mentioned above would be the obvious choice (although I don’t think it can output to Bluetooth headphones).
If speakers are required, that’s another set of products or the Denon plus some very cheap/end of line speakers.
jjbomber
denon dm41dab and some speakers , have s look on the richer sounds webpage.
They've taken the USB off the 41. Not sure if there are any of the old 40s out there.
Otherwise there is the Onkyo:
PhilT
6
Thanks for your replies everyone
The dm40 dab with the USB is still available @ £315
So i guess its that or the Onyko CS-265DAB @ £176
so the next question has to be
Does the differences between them (that me being ignorant can't really see) justify price difference?
Gray
That price must include speakers Phil. Right?
All I can tell you is that I made my brother (also called Phil) buy a DM40.
His one came without speakers so I put some Kef's on it. Sounded good.
He uses the USB input to play FLAC files - think I'm right in saying that on the 41 they dropped the USB feature, so that model was probably no good for you anyway.
It's display, though bright / clear, is only a 2-line affair so that may be your deal breaker. There's also no Bluetooth.
Don't think you'd be disappointed with the sound though - subject to the choice of speakers - and I reckon it's good enough to drive some decent ones.
PhilT
6
Thank you once again for your response jjbomber
The Lemega does have what appears to be a much more informative screen
As a thought
Is it possible to porchase some kind of bluetooth dongle that I could plug into a music center that would enable it to communicate with other bluetooth devices?
