Looking for a new amp
denontillidie
15
I am looking for a new amp which will be used primarily for playing music on.
I have a denon cd player, cambridge audio artic inter connects, and some b&w 683 speakers connected through QED ordinary biwire.
my front room listening position is about 3metres from the speakers and the total size of the room is 3m by 4m.
i am looking to spend up to 500 pounds, will go higher if absolutely neccessary. but i dont want to cut corners.
let me know what you think,
cheers,
Rob.
This should grip your speakers rather well and keep it all nice and tight...
http : // www . superfi . co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1797
denontillidie
15
sounds like a nice choice. i had not clocked that one for my shortlist, but i will be giving it a listen.
my shortlist so far is:
rotel ra-04/6
denon pma 1500
pioneer a-a6
nad c352
any other amps that would be worth a go?
T
the record spot
£500 will get you into some seriously good amp territory if you aim for the used market. Have a look around some of the independent dealers secondhand kit online and see what's available. Might be you clap hands on a peach of an amp you'd otherwise not be able to achieve. Worth a look anyway and some dealers (like Billy Vee in London for instance) offer a warranty anywhere between 3 months to a year.
