Hello,
l would be grateful for forum members opinion as to the Logitec SqueezeBox Touch (SBT). l have, recently, bought a pair of AVI ADM9T's, which l'm very inpressed with & suit me down to the ground. At present they are fed via a laptop (windows), USB out, into a CYP D-150 DAC & then optical out. l listen, mainly to Spotify (premium) & the sound is excellent.
However, l'm looking to the future & freeing up the laptop, from a fixed connection & considering the options. My first thought was the Apple Airport Express & use Airfoil on the laptop, which would give me the wireless option. However, more recently l've been considering the use of the SBT, which l believe will give a good SQ & option for better resolution in the future.
l would value peoples opinion on these options & any other potential solutions, that are practical, reliable & fairly simple to set up & use.
Particularly, if l was to use the SBT can l use it independantly of a laptop/PC, as the, albeit limited material l have read; doesn't make this clear.
Thank you in advance.
