Leave rDAC on 24/7??
starkiller
14
Just got a rDAC the other day and having an issue. Have all my gear controlled by one switch..flip--on--flip--off 🙂 However, after doing this at the end of the day, the next day when i go to listen the rDAC, even though the front green light is on, will not pass music until i power it off and on using the switch on the back of it. Is this normal? If so, it must be ok then to leave it on 24/7 and figure out a way to run a seperate power cable to it then?
thanks for the help!
Don't have one but it seems to me the rDac wants to be turned off by its own switch and on also. Likely some logic inside linked to the switch that doesn't do it's thing when the power is just chopped and applied again.
Which input is active when it is powered off/on? This is not uncommon with USB, which can sometimes be fussy about the order in which things are powered on. I have yet to come across this with S/PDIF inputs.
