I am planning on purchasing a new LCD TV for my bedroom.
I want it to be mounted on a bracket that can lie flat against a wall at 90degrees to the wall against which the pillows are rather than the opposite wall, if that makes sense (I will want to pull it out and angle it between 45-90 degrees from the wall it sits on).
Distance-wise, I'll be approximately 2.5-3m from the screen.
I'm currently looking at the Sony KDL20S3000 (as the newer model [KDL20S4020]apparently can't be wall mounted); but have started to think that I could possibly afford to go up to a 23" screen.
Any recommendations? Or is this the best bet for now? OR should I contemplate going up to a 26" inch?
