latest spec
markyboy156
203
hi all
i want to build a very powerful hi spec pc with the very best overclocking benchmarking and very best gaming performance pc currently available i a full listing of the very best components needed thanks
i did not get the answers i needed from my last post
If you need to ask the question, then forget about building one yourself, as it requires knowledge and skill. (Just bolting together some top rated components is just a recipe for disaster) therefore go to a specialist PC builder (Most online stores have a custom build section) and have one built for you, as that way you will get the best value and performance for your buck.
If you want to learn, then go to dedicated computer forums, or get yourself a computer magazine subscription, that way at least you will understand the basics. (Professional knowledge takes time to acquire)
Hope this helps
Bill
