- Aug 10, 2019
- 2,556
- 5
- 0
Hi all, I am fairly new to this, but after some deliberated research, I am looking to get close to a HiFi sound as possible from my computer based music.
My current setup is Sennheiser HD555's from a 3.5 audio output on a Macbook Pro, and after listening to my headphones via a HIFI system, realised I was not getting the full potential from my headphones, hence this quest began. After researching I have been looking to get either of these following setup's and would like advice if it would be good or if there are better...
[1] Macbook > Beresford Caiman via USB, Graham Slee Solo Amp > Sennheiser HD555
[2] Macbook > Cambridge Audio DACmagic > Graham Slee Solo Amp > Sennheiser HD555
A third option would be to have a Presonus FP10 (or firepod) via Firewire to a dedicated headphone amp as I also do home recordings, but I do not know if 1. if it is a DAC and outputs an analogue signal, or 2. if it is, whether or not it would be a suitable DAC for HiFi listening. Here is more information on the product...
http://www.presonus.com/products/Detail.aspx?ProductId=5
All music is played via iTunes and ripped in AIFF/WAV lossless format. Are these good choices? Or are there better? Im trying to get the best performance I can with the headphones I have, possibly in some near future looking to upgrade to HD650's, but for the time being I'm sticking with the HD555's.
Any advice would be very welcomed 🙂
