anyone own any of the klpsch speakers as i would be intrested to know if they are any good for rock .metal and some softer music too . are this to hash on the sound front ? and which is one in the range would be good to try in a demo .. thanks
Blacksabbath25 said:anyone own any of the klpsch speakers as i would be intrested to know if they are any good for rock .metal and some softer music too . are this to hash on the sound front ? and which is one in the range would be good to try in a demo .. thanks
did see some floor standing ones on youtube but so far my list of speakers go for demoing are the pmc 21 , 22s ,KEF ls50s but they look to small for metal music but will not no till i demo them and KEF 300r.s or dalis the mk2 ,mk2 but will go the floor standing if book shelf speakers do not cut it . the only ones i have had a demo with was the pmc 21 which are good for there sizechebby said:Blacksabbath25 said:anyone own any of the klpsch speakers as i would be intrested to know if they are any good for rock .metal and some softer music too . are this to hash on the sound front ? and which is one in the range would be good to try in a demo .. thanks
Klipsch Heresy III
http://www.audiocounsel.co.uk/contact/
I did not realise that they do not sell them as pairs they sell them per speaker which strangedavedotco said:If you are serious about this the answer is simple, depending on budget.
Adam A7x..... £800
Mackie HR826 -2...... £1100
Event Opal...... £2000
All have various degrees of eq to help with speaker/room interfaces and enough headroom to play loud enough without harshness.
Blacksabbath25 said:I did not realise that they do not sell them as pairs they sell them per speaker which strangedavedotco said:If you are serious about this the answer is simple, depending on budget.
Adam A7x..... £800
its more going to be that i will buy the pmc 21s or 22s pmc as i do not no much about actives speakers as i do like a warm sound and not a cold oneMark Rose-Smith said:Remember to just be aware that some studio derived monitors will be very revealing,uncoloured and accurate to the source material.This unfortunately could make for some very unpleasant listening sessions,and the very reason pmc introduced the twenty series,go check out some of there active speakers and you'll wince at the cost of certain units,but they are the masters of active and not too shabby at the passive gear either.
davedotco said:Another advantage is the lack of bass bloat, no spurious 'bass warmth' to muddy up the midband, so again, improved clarity and precision. Some will tell you this is not 'natural' or 'musical' but this is misguided, clean tight bass is what you get and once you adjust, you will not go back.
ok thank you i will do my home work and look into them thank you sounds like what i am after but what part will the event opals have with my amp ? as the opals have there own amp inside them . getting a demo is a big issue for me as there no were round me who sells them but seen a second hand demo pair for £1.895 on ebaydavedotco said:The active suggestion is largely based on the budget and type of music being played.
Hard rock/metal is heavily compressed which tends to squash instruments together, losing clarity and separation. The active speakers mentioned are more dynamic than the conventional offerings at this level and will help tremendously in this respect, improving clarity and separation.
The Event Opals have quite sophisticated eq, the others somewhat less so, but they have enough flexibility to adjust bass for room position and high frequency to suit program material. Take no notice of the 'nearfield' designation, it is meaningless in this context.
Finally, these speakers are designed to be used intensly, for hours and hours at a time, professionals would not buy them if they were difficult or tiring to listen too.
chebby said:davedotco said:Another advantage is the lack of bass bloat, no spurious 'bass warmth' to muddy up the midband, so again, improved clarity and precision. Some will tell you this is not 'natural' or 'musical' but this is misguided, clean tight bass is what you get and once you adjust, you will not go back.
The man likes warmth though. He said so. Again we are at that impasse of personal preference vs measured accuracy that 'active vs the rest' discussions seem to hit.
Those discussions have traditionally ended up with active proponents telling the poster "Do what's good for you, you'll get used to it even if it hurts at first ...".
your right the marantz pm8005 is a very good sounding amp and been sitting here playing AC DC powerage and it sounds very nice and only just got it and now run in which had taken me 2 weeks to run it in but sounds good and i think i will go for a passive speaker still but a much better speaker that can handle things better then at least i can get a demo with the passive stuff but thanks to the other chap on letting me know about the other actives something i will keep in mindMark Rose-Smith said:Your lovely new amp would be all but redundant.you might be able to use the pre amp section though.
lol the best album sabbath did was the first one and then the second one but i do think ozzy did a lot better on his own . seen sabbath live myself and they were amazing and seen ozzy solo live 8 times live but never meet him which is something i have always wanted to do . ian Gillan was in deep purple think but did not like him or dio as sabbath was ozzy anyway . but thanks for the info on the speakersBenedict_Arnold said:Back to the subject, perhaps the OP would like to know I have a pair of newish Klipsch Reference II speakers, and NO, I am NOT trying to sell them.
They're the tall thin ones (can't remember the model number) with 5 1/2 inch mid and bass cones, and I would NOT recommend them for heavy metal at all. The bigger Klipsch models, maybe, but not the smaller ones. They simply don't "move" enough air. They were a Christmas present from 'er indoors, otherwise they would have been on Fleabay years ago.
What might be worth looking out for if you're in the market for American speakers is a pair of Boston Acoutsics, the ones with powered subwoofers in the base of each floor standing cabinet. They move a LOT of air. I wouldn't recommend them for Mozart concertos, but for a good old blast of Paranoid or Heaven and Hell or whichever your fave Sabbath album is, they might be great.
FWIW I saw Sabbath, post Ozzy departure, at Reading Festival in 1983 (I think it was - all a bit fuzzy now where are my pipe and slippers?). Ian Gillan was singing for them. Flaming Gillan got his bloody bongo drums out during his rendition of Paranoid and nearly got bottled off the stage. Served him right.
Blacksabbath25 said:ian Gillan was in deep purple think but did not like him or dio as sabbath was ozzy anyway . but thanks for the info on the speakers
Benedict_Arnold said:Blacksabbath25 said:ian Gillan was in deep purple think but did not like him or dio as sabbath was ozzy anyway . but thanks for the info on the speakers
Yes.....
Ian Gillan was to Deep Purple what Ozzy was to Sabbath.
Sigh, youngsters!!
DocG said:I get confused matching these statements to your avatar, Mr. Arnold...*smile*
