Klipsch X11i
joscejrod
32
Hello. Are you going to review klipsch x11i? Could you compare them with shure se425? Thanks a lot
Reading Klipsch website, it states that the X11i is identical to the X10i apart from it's colour and cable construction :-
http://www.klipsch.com/Education/headphones-faq
What is the difference between the old X10i and the new X11i?
The X11i is identical to the iconic X10i with a few subtle improvements – The cables on the X11i are square instead of round to be tangle-resistant, and the cables are also re-inforced with Kevlar for added strength and robustness. The tail has been improved by being made of a tougher durometer of elastomer to prevent breakage. The color of the aluminum housing is now dark silver instead of copper. The same great acoustics that the X10i is known for are identical to the X11i, as well as the fit and comfort.
What Hi-Fi already has a review of the X10i so you should get all you need from there :-
http://www.whathifi.com/review/klipsch-image-x10i
