Hello i currently use the centre speaker from the Kef 3005se speaker package and was wondering if i was to purchase the Kef Q9C centre speaker would it be worth it or would i be better sticking with what i am using at the moment. I have the Kef Q7 speakers bi amped to my receiver so the
Kef Q9C would match it.
The kef centre speaker that came with my kef3005se speaker package is model number HTC3001B.
Would there be any benefits or is the one i got with the Kef speaker package better.
Frank Harvey
567
What you already have is a better match, but if you're looking at adding some floorstanders from the same range as the Q9c, then go ahead - it will sound much better than the 3005 sentre speaker.
well i am not looking to replace my Kef Q7 Floor standing speakers just the centre from the kef3005se package to the Kef Q9C
which centre would you use with the Q7 ?????
Thanks very much i am pleased to hear that i will go for the Q9C
thanks for your help :)
