KEF Q7 SPEAKES FRONT) KEF Q3 REAR) AND KEF Q6C CENTRE) CONNECTION
Hello
i have currently hooked up my kef q7 (bi amped) to my onkyo tx-sr605 receiver and wanted to know how i would connect the centre q6c and rear q3
The problem is this the centre has 4 connections high x2 and low x 2 frequency connections as well as the rear q3 speakers which terminals do i use just the high or low or can i mix
for example centre speaker (left high and right low) terminals to connect to my recevier as i surely cant use all the 4 connections on the centre and rear speakers as the receiver only as 2 connections for the centre and 2 each for the rears left and right.
is there such a receiver when i can connect all speaker terminal to one receiver as not seen one with enough speaker connections on the rear of one
ear
118
U must connect the highs to the lows on the speakers. With plates that come with it or with wire.Then connect wire to the lows and to the amp.
so once i connect the highs to the lows with the wires on each speaker left to left and right to right can i simply pop in a banana plug from the lows on each speaker terminal straight to the receiver as i use banana plugs at the moment for my Q7 which are biamped.
will this work with the woofer and tweeter for the individual speakers.................
Andrew Everard
1,878
And assuming you've bought the speakers new, the jumpers between the terminals should already be in place on the centre and rears. You know, the ones you removed when you biamped the Q7s...
