P peterpan New member Oct 21, 2008 160 0 0 Apr 2, 2013 #1 I like the Kef R300 and R500. Music symfonic metal and pop. But in my room i can place the speakers 4o cm from the walls. Isn't the R300 then the better choice? Kef says the R500 must at 1 metre from the walls.
B BigH Well-known member Dec 29, 2012 142 19 18,595 Apr 2, 2013 #2 Standmounts are generally better when closer to walls than floorstanders.
Frank Harvey Well-known member Jun 27, 2008 567 1 18,890 Apr 2, 2013 #3 Room dependent - different rooms, different results.
B BigH Well-known member Dec 29, 2012 142 19 18,595 Apr 2, 2013 #4 Yes that is true, what are your walls made off? Are they solid, brick, breeze block, concrete, plaster board, wood, or cardboard?
M MikeToll New member Jul 7, 2010 4 0 0 Apr 2, 2013 #5 Floors make a big difference too, I am lucky and have a solid brick floor which makes for wonderfully tight base.
plastic penguin Well-known member Apr 28, 2008 6,790 3,382 36,570 Apr 2, 2013 #6 You'll need to experiement as my RS6s are fine 12" from wall.
P peterpan New member Oct 21, 2008 160 0 0 Apr 2, 2013 #9 Yes; i thought also. I have had the MA Rx6. Overblown bass in my room. For the R300 i need a pair of speakerstands. Which will be fine?
B BigH Well-known member Dec 29, 2012 142 19 18,595 Apr 2, 2013 #10 I would look at the Atacama Duo 6 which are about £60, check the height you want the tweeters about the same height as your ears.
