- Aug 10, 2019
- 2,556
- 5
- 0
Hi
Does anyone use the XT cable with the KEF 3005SE stands & speakers and if so does the cable fit easily through the cable run in the KEF stands?
I'm using Gale symphony 200 on the fronts at the moment and want to upgrade to something better. The Gale was tough enough to feed through so I want to make sure that won't be a problem with more expensive cable.
