Yeah, I have just been listening to them and not that impressed to be honest, I prefer my B&W P7 headphones.If you don't need active noise cancellation and something portable you can do WAY better on sound quality.
Cheers Buzz.My friend bought some at Gatwick airport Dixons Travel last month. I think he paid about £220 after various discounts. I only had a brief listen on the plane, but they sounded good to me and the noise cancellation is a great way to block out the surrounding world.
Turn up the volume?This morning I had a listen with my TV wirelessly why’s it so quiet?
Turn up the volume to max in the TV menu headphone output and control the volume with the headphones.This morning I had a listen with my TV wirelessly why’s it so quiet?
Cheers Buzz. It will be lightyears away before he uses them on the plane againbuzz_lightclick said:
You could try re-pairing the headphones - sometimes works...Still no luck, tried the App but that didn’t work!
Samsung 65Q950R QLED TV.You could try re-pairing the headphones - sometimes works...
Which TV is it?
Did wonder. I know there have been numerous issues/complaints about Samsung TVs and Bluetooth headphones. Basically saying that only Samsung headphones work properly with Samsung TVs and that the "Bluetooth" on the TVs was far from standard...Samsung 65Q950R QLED TV.
Such as please? Thanks.If you don't need active noise cancellation and something portable you can do WAY better on sound quality.
