Hi All, can I ask for your advice?
As you can see I've just upgraded to 609, do you think it's worth buying another Subwoofer ? I have a KEF 2001 speaker set up including the KEF subwoofer. If so can someone please advise as to the correct wiring from Subwoofer to the Onkyo. At the moment I have a Red & White wire plugged into Subwoofer ie Line in Right and Line in Left both going into Onkyo but Onkyo tell me that two Subwoofers can be plugged into it. At the moment the two Subwoofer connections on the Onkyo are taken up with the Right Line / Left Line in plus??
Your help and advice would be very much appreciated.
As you can see I'm a bit lost - I've only just found out that using the Optical connections from SKY HD to Onkyo gives better sound.
