IXOS or QED Cabling?
I'm in the process of purchasing a home theatre system and was wondering which one is better overall as many shops stock both?
That's an impossible question to answer really. Both brands have large ranges to suit different budgets. QEDs budget speaker cable may be better than IXOS's, however IXOS's high-end optical cable may be better than QED's (hypothetically speaking of course). It's best to decide on your budget for whichever cables you need then find some reviews or try out the cables yourself.
lee37
35
usually i check out what hifi mag
but i did my research and this is what i ended up with:-
QED QUNEX 2 INTERCONNECT £13
QED PERFORMANCE OPTICAL DIGITAL LEAD £30
QED QUNEX PERFORMANCE HDMI-P HDMI £50
QED PERFORMANCE COAXIAL DIGITAL LEAD £25
QED XT350 SPEAKER CABLE £13 metre with
QED AIRLOC PROFESSIONAL-FIT 4MM BANANA PLUG £5 each
i also hace chord rumour 2 £11 metre for my surround sound speakers with ixos banana plugs on
and i cannot fault any of these cables
lee37:
Opposition: 6 Home: 0
Octopo:lee37:
Ahh - Home 0.25 surely if you read the last line of the post.
lee37
35
thats a helpful comment
what do you suggest if i am totally wrong then thinking that most of these have has 5 stars from what hifi
lee37:
ÿ
Thankyou.
You're not wrong. The QED's are excellent cables.ÿ
