Grumble02:Yes - ScotlandITV1 HD isn't availble via the EPG in Scotland due to STV/licensing issues.
However it can be manually added and watched via "Other Channels". Also STV HD is due soon and will be available via the EPG in Scotland, but is currently testing so is also available via "Other Channels".
To add the channels manually,follow Clare's instructions
HERE, but substitute the parameters in that thread with the following,
Frequency- 10.936
Polarity- Vertical
Symbol Rate- 22.000
FEC- 5/6
A version of both STV HD and ITV1 HD are available on this transponder so you can add both once you've scanned it. STV HD may be labelled as 3855 so add that if you cant see STV HD in the list of channels.
