itunes library
Hello
Due to space i have moved my music files from my mac to an external harddrive,and now have to access that to play music,what have i done wrong?
I dragged and dropped my i tunes lib to a crossfire external,now when i go to play a track aÿmessageÿsays file cannot be found,of course now over in crossfire,surely some cockup made by me.
Thanksÿ
professorhat
992
22
18,895
Sorry, finally found the post I was thinking of and it's not actually the solution for the issue you're having. However, assuming you really did move absolutely everything, I'm pretty sure all you need to do is just highlight everything in your current iTunes, right click and choose Delete to remove them from the Library, then go to Preferences > Advanced and change the location of the library to your new drive.
I have to point out, I've never done this, but from what I can see it should work. I think you may lose your playlists though. Might be better to wait till tomorrow when some of the more knowledgeable iTunes regular forum posters are on and see if there is a better way.
John Duncan
professorhat:Might be better to wait till tomorrow when some of the more knowledgeable iTunes regular forum posters are on and see if there is a better way.
If I see one, I'll let you know...
Let me just read this again and work out the best way forward - basically your iTunes database still thinks your files are on your hard drive when they're not - I thing the best way forward may be a library consolidation, will check.
For future reference and others with this issue. I think the simplest thing to do is start iTunes while holding the 'alt' key (on Mac - not sure on PC ctrl?), this allows you to choose which library you wish to use. So, if you moved the whole lot onto a external HD (i.e. a new path, you can just navigate to the new location).
