I am well and truly baffled by my hifi system and hope that someone here can shed some light on a problem.
Basically the problem is the right DM10 speaker is louder than the left one and I have no idea why. My system consists of three sources; a PC (connected via digital optical cable), a record player and a portible MP3 player which are all plugged into a Yamaha DSP-E800 receiver which is used as a DAC and pre-amp.
No matter which source is used (either digital or analogue) the right speaker is always louder than the left one. However if I remove the Yamaha receiver from the system and plug the sources directly into to speakers then they work perfectly with both of them playing at the same volume.
This made me to think that there must be a fault with the Yamaha reveiver so I've just purchased a Marantz NR1504 receiver to replace it with. I swapped them over today and lo and behold it still has the same problem of right speaker being louder than the left one with the Marantz receiver too.
The next thing I did was check that all of the RCA cables are all plugged in correctly just in case I'd done something daft like mixing up the mono subwoofer cable with one of the speaker cables but these are all plugged in correctly. Just to be certain I quadruple checked the cables and have even put sticky labels on the end of each one to be sure that they aren't mixed up.
Next I wondered if one of the cables might be faulty and is somehow acting as an attenuator to the left speaker so I tried swapping all of the cables over for a new set but even with different cables the problem still persists.
This has left me scratching my head as to what else could be causing a channel imbalance when a receiver is in place between the source and the speakers.
Anyone have any ideas?
