Is there such a thing as av storage that will take a heavy AV receiver Blu Ray player that mounts on a wall needs to be 6ft air
Ian986
99
As title say really due to lack of space I need a way of having my receiver up 6ft high bolted to wall have on a shelf at moment don't look to nice.The Only ones I have seen can only take 10k or would not be big enough to take Onkyo 809
Messiah
There are shelves that would take the weight but not the depth.
I used to have an amp, CD player, graphic equaliser (yep, you read that right!) and a small fish tank on a shelf once. It was simply 2 very large brackets fixed to the wall with some big screws and a shelf cut to fit.
Guess it also depends if it is a brick or plasterboard wall and where the shelf can be supported.
What about this:
http://www.audiovisualonline.co.uk/product/3045/omnimount-moda-mwfs-wall-rack
Ian986
99
Thanks guys that is good advise I like the look of the Omnimount maybe a solution and I can speak with them but I would need two side by side keep the idea coming and thanks again
Speak to Hi-Fi racks regarding your requirements. They can custom make one for you.
