muljao said:
dalethorn said:
muljao said:
Thanks Dale,
if you were to recommend something at the lowest budget that may fill the criteria, what would you recommend?
The Bose QC35 is probably the only solution. There are cheaper, but their qualities are unknown to me. In the end, most people who find cheaper end up spending more fixing unexpected issues.
I think you may be correct
I checked Amazon for Bluetooth noise-canceling headphones, and after subtracting out the on-ears and the truly awful brands, settled on a couple of Sony's that were around £109 and £179. Amazon tries to block purchases from other sources in their reviews, but sometimes it's good to look at those too.
Anyway, one thing I do is start with the 1-star reviews to see what the complaints are there, then check the 2-star reviews and so on. After you wade through 50 or so you'll see the patterns and be able to see where the real limitations are.
One tip that nobody ever mentions: While the QC35 noise canceling is exceptional on public transit and so on, trying to listen outdoors in wind might be a problem, because the headphone uses mics on the outside to monitor and correct ambient noise. I've been in windy situations outdoors where a standard closed-back headphone is better.
