Is it worth upgrading my Blu Ray Player?
Mickgw
72
Hi everyone
I currently own a Panasonic BDP55, is it worth the upgrade to the new Sony 760, just curious, i have a Sony Bravia set, cant remember the number but it got 5 stars at the end of 2008.
Mike Worrall
I do own same player you want to upgrade. till now I am totally satisfied with it's performance. I think it will worth it.
I have a BD55 too. I don't feel the S760 will provide you with much of an upgrade. I would keep the 55 and would consider an upgrade for a Denon 2500BT instead.
Thanks for that, is it worth upgrading at all as i only have a 40 inch screen, how about the the top end Sony or will that be best used with a bigger screen?
Mickgw:Thanks for that, is it worth upgrading at all as i only have a 40 inch screen, how about the the top end Sony or will that be best used with a bigger screen?
With a 40 inch screen, I would just keep the 55.
