- Apr 24, 2012
- 15
- 0
- 0
Hi everyone, A dumb question perhaps but here it is: Is it bad for the signal to pass through two DACs? It can't be good to add a step in the chain, but is it especially harmful here?
I have been using an Asus Xonar Essence ST soundcard, which uses a Burr-Brown PCM 1792A DAC to convert signals(127dB SNR, Max. 192kHz/24bit). Retails for about US$200. Am wondering how pricey a DAC separate I would need to hear an improvement in the sound. If I upgraded to say a Rega DAC or Arcam rDAC, would I need to remove the soundcard, and run the signal off the motherboard's audio outputs? I have about US$1,000 (800 pounds) available for an upgrade and wonder where it should go, as currently the sound is alright but want punchier, tighter. Maybe its the speaker-amp.
Incidentally, from the soundcard, the signal goes out RCA jacks through Chord Crimson interconnects to a Rega Brio-R then through Chord Carnival Silverscreen speaker wire to Monitor Audio Silver RX1. Thanks!
On a side note, what do people think of the claims made in this science-based article, which holds "there is no point to distributing music in 24-bit/192kHz format. Its playback fidelity is slightly inferior to 16/44.1 or 16/48" http://people.xiph.org/~xiphmont/demo/neil-young.html
