GSB said:If the bi-amping is done with an integrated amp and an avr i can imagine this would benefit av,but would it be so for hifi?
abacus said:Forget Bi-wiring as while it may alter the sound, it will not be as the designer intended, thus producing an inaccurate sound.
Hope this helps
Bill
GSB said:I was told by a very trusted retailer that bi amping with my avr(using the spare suround back ch)would make no difference,could you expand on this,out of interest?
GSB said:So to get a worthwhile result a seperate power amp should be used to bi amp?(my oppologies for being a pain in the rear)
GSB said:Bill,i was told by a very trusted retailer that bi amping with my avr(using the spare suround back ch)would make no difference,could you expand on this,out of interest?
abacus said:GSB said:Bill,i was told by a very trusted retailer that bi amping with my avr(using the spare suround back ch)would make no difference,could you expand on this,out of interest?
A passive crossover consists of inductors, Capacitors and Resistors, and is chosen by the designer to get the best compromise with the drive units and cabinet.
As the HPF and LPF are connected together there will always be interaction between them, which the designer will try and alleviate as much as possible. (The more expensive speakers generally use better components for better compatibility)
When you separate the HPF and LPF you remove this interaction thus the HPF and LPF can do their own thing without interference so should therefore give a bit better sound. (How much will depend on the speakers and amps used)
The second part of the equation is the amp itself, if it is reproducing plenty of bass then it is consuming large amounts of power from the power supply which can affect how pure the power is for the rest of the frequency range, If you separate the bass and treble into their own channels there will less chance of them interfering with each other, (If you can use separate amps completely than you will reduce the interference even further) thus giving a much more controlled sound.
How much difference the above makes will be dependent on the speakers and amps used, but there will always be some difference.
Hope this helps
Bill
CnoEvil said:abacus said:Forget Bi-wiring as while it may alter the sound, it will not be as the designer intended, thus producing an inaccurate sound.
Hope this helps
Bill
Whereas I am somewhat sceptical about the benefits of Bi (Tri)-wiring, the Kef manual specifically shows how to do it, which they wouldn't do, if the designers felt it would be detrimental.
I'm not worrying,or even thinking of bi wiring bi amping or anything else bi :shifty:CnoEvil said:GSB said:So to get a worthwhile result a seperate power amp should be used to bi amp?(my oppologies for being a pain in the rear)
Hi-Fi is all about opinions, which often conflict.
.......and mine is that you need to take the AVR's Pre-amp out of the loop, for 2 channel, as it will be the weak link. You are likely to get an improvement, but maybe not a VFM one ie. compared to getting a stereo amp.
In your case, I think you have done the right thing, so I wouldn't worry.
