Ipod Touch Screen Protector
Yeah, I have to say it's brilliant too. I've just ordered a new iPod Touch 64GB and got one of these for it (although I got a ZAGGskins one rather than the plain InvisibleShield). The difference being that the ZAGGskins are the InvisibleShield + a custom design of your choice underlayed the shield on the back of the iPod; this really makes your iPod unique.
I use this one on my iPod Touch. It does feel a bit cheap, and the touch sensitivity is reduced ever so slightly(99% of the time, it's unnoticeable though). My friend, on the other hand, does not have a screen protector on this iPod and his screen is screen is scratched quite badly. For some unfathomable reason, he keeps his iPod in the same pocket as his keys. Needless to say, the keys win.
The way I see it is that the above-linked screen protector is so cheap that it's worth a shot, and it means you don't have to worry about being too carfull where you keep your iPod Touch. I'm definitely glad I have it. Just make sure that you take the time to affix it properly otherwise it will be noticeable and really cheapen the look of your iPod Touch.
peter8171
47
Just got the Invisible Shield for my new touch. Seems to be working fine so far, no real noticeable reduction in touch sensitivity and it is protecting the screen really well.
The cover for the screen was quite easy to fit and went on well, however, I had a real struggle with the cover for the back of the touch. It was really fiddly and is still not really very good. At least you can remove it for another go so I'll have to have another try next weekend.
HI GUYS JUST BEEN LOOKING INTO THE INVISI SHIELD AND HAVE TO SAY THIS PRODUCT LOOKS IDEAL FOR ME SO HAVE JUST ORDERED IT FOR MY NEW IPOD. I AM WONDERING IF ANYONE CAN RECOMEND A SUITABLE CASE FOR MY 64GB POD. IDEALLY I WOULD PREFER A RUGGED SILICONE OR RUBBER VARIETY TO PROTECT IT BUT ALSO LOOK SMART. HOPE SOMEONE CAN HELP
Andrew Everard:And also if anyone could tell him where to find the CAPS LOCK...
How cruel Andrew, not everyone knows how to turn it off!
GetCarter
21
HMV do a version of the Invisible shield, bought this from them for £5 and fits a treat, Just for once the High Street is cheaper than online!
