iplayer through bluray?
Can i get iplayer etc through my br?
There are so many things online for tv as in bbc/itv/sky player and lovefilm etc, How if possible and what is best way to get these with my set up, or do i need a box of some sort, I have full wifi in front room, if required i can hard wire ,
I do hope there is a way and that you can help me
thanks look forward to your replies
The_Lhc
1,176
Slightly longer answer, no, not with THAT blu-ray player but there are some on the market now that can access the iPlayer.
I just can't remember which ones they are. Hey, I did say it was only a slightly longer answer...
Cheers guys,
What would i need to make it happen? or is watching through a laptop only way? I would like good pic qual
I do have wii of which i heard a rumour may work, but does that mean all the people wont have arms or legs
The_Lhc
1,176
Err, if you've heard a rumour that the Wii supports the iPlayer why don't you try it and find out? It certainly should work, otherwise you're looking at a new blu-ray player, unless that LG one you've got there can do it, but I couldn't tell you that.
professorhat
992
22
18,895
You can indeed get iPlayer through the Wii if it's hooked into the internet. From Nintendo's website:
To use the new BBC iPlayer on Nintendo's Wii, Wii users should download the BBC iPlayer Wii Channel from the menu screen of Wii Shop Channel. Once downloaded, users simply click on the BBC iPlayer icon to launch the new full screen service, then select and play their favourite BBC TV or radio programme that they want to watch.
Sorreltiger
42
iPlayer via the Wii is very easy to use. The picture is full screen, but rather soft with washed-out colours. However, the kids happily use it to catch up with some of their stuff.
