i have recently changed my interconnects to Chord Chameleon Silver Plus and now think my system - Roksan Kandy CDP, Amp and Power Amp sounds too bright - i am going to swap my old ones back in at the weekend to test - what i am wondering is there any hard and fast rule that says you should use same interconnect for example from CDP to Amp and Amp to Power Amp or can you mix and match? could it be a case that if i just swap the one from the CDP to the Amp for one that sounds less bright that will solve the problem or would i need to swap both? I am sure i am going to be told try and see what my ears say but just wondered if anyone had experimented with this - i don't want this to turn in to an every cable sounds the same debate as i think some make a suttle change and some a dramtic one. I would be interested to hear what other use with the Roksan Kandy kit.
