Interconnect to match my system?
What would you recommend for my system, at the moment I am using a Cambridge Audio Pacific for £30 from Richer Sounds.
Must be 0.5m long
(System Below)
Or is the one I have good enough?
Can't find any reviews on it...
Don't know much about your cable but I'd say try Chord Cobra if you are not satisfied with yours - Cobra retails for around 55- 60 but can get it for 26- 27 on fleebay. Chameleon S+ is better but double the price - not sure if its worth it with the speaker cables you have.
EDIT: those prices are for 1m, 0.5m will be cheaper of course.
Thanks, I'm not dis-satisfied with my cable, but I have never used anything else so if there are improvements to be had then I'm up for it for £60.
Pmaninit:Thanks, I'm not dis-satisfied with my cable, but I have never used anything else so if there are improvements to be had then I'm up for it for £60.
I would say that your speakers and DacMagic are better than your amp and a step up in interconnect would not be worthwhile unless you upgraded your amp. The cable you have at the moment is fine.
Gerrardasnails:Pmaninit:Thanks, I'm not dis-satisfied with my cable, but I have never used anything else so if there are improvements to be had then I'm up for it for £60.I would say that your speakers and DacMagic are better than your amp and a step up in interconnect would not be worthwhile unless you upgraded your amp. The cable you have at the moment is fine.
Hmm, okay. Well I don't think I'll be upgrading any time soon, thanks for your opinion.
Agree. I used to have one bye the way (pacific interconnect) and it is a pucker cable for the dosh. Got 5 star in WHF mag and they said 'Worth every penny' which considering the price you can pick them up for it definately is, and worth keeping.
Ah, that's good; it's nice to know that the cable isn't regarded as rubbish, thanks
