Integrated amp with dac
nb01somea
I'm looking to for a Integrated amplifier with a built in dac that supports full 24/192 ALAC files. Any suggestions?
nb01somea
I'm currently using my AK100 as a dac from my macbook into a Amptastic mini t amp driving a pair of Q Acoustics 2020i. I'm looking to spend up to £1500 on the right amp+dac and building a new system round that.
CnoEvil
556
14
Some possible suggestions:
Peachtree Nova 125
Leema Elements (with DAC module)
Bel Canto C5i (ex-dem)
Creek Evo 100A (with RUBY DAC module)
rainsoothe
901
436
19,270
hi.
heard great things about the Hegel H80 and Quad Vena, also the Peachtrees - so those are defenately worth auditioning.
You could ofc go for a streaming sollution, for which I would defenately recommend the Naim Unitiqute 2, which you could later upgrade with Kef LS50 and NAP100 if you think you need more powa - thats what I would do with that budget at least, but then again I just love and am addicted to the Naim sound.
Happy_Listner
23
1. From Norway, the Hegel H80, $2000 in the USA. I heard it and it's very good! Great DAC too.
Review: http://www.theabsolutesound.com/articles/hegel-h80-integrated-amplifier/
rainsoothe
901
436
19,270
btw, there's a used Supernait 1 on the bay from a guy that gives 14day return, so if you're stationed in the UK, you should really check that out. It has an inbuilt DAC, but only coaxial and optical inputs - if you have the option of using that, you must give this an audition, it's a beast of an amp.
gowiththeflow
52
11
The latest iteration of Peachtree's Nova series are the recently new SE series. Well worth a look IMHO.
Your budget covers both the Nova 125SE (£1,149) and Nova 220SE (£1,495).
MUSICRAFT
Hi Happy_Listener
+1
All the best
Rick @ Musicraft
Reijer
18
@np01: Have you listened to different amplifiers as this can be quite enlightening?
Yesterday I bought an amp that I did not have on my audition list and that I would never have thought of.
