- Aug 10, 2019
- 2,556
- 5
- 0
Hi I am in the process of putting together a home cinema and need some advice.
After much hunting around I purchased an IN78 for ~800GBP, so now the question is what to use as a source for it?
Would the Samsung HD870 be a good option?
I will be using it in a 4.6m x 4.6m room, and plan to sit about 3.5m from the screen. The room will not be completly blacked out, so do I go for a screen with high gain or what?
Also doing some calculations on screen size it looks like 100inc is going to be the size required, as the projector will be around 4.2m from the screen.
Any suggestions on screens? I am happy to have a fixed screen, so as to get as high a quality screen as possible for the money.
