In wall subwoofer required
Hi all
space issue means I am hoping to replace my Dali Ikon Subwoofer with an in wall subwoofer. It will be used in a Dali Ikon 6 5.1 set up. Budget up to £1000, although would prefer to spend nearer to £500 if possible. I'm guessing I'd have space to accomodate up to a 10cm depth. I'd also prefer not to compromise the quality. Any recommendations please. Thanks, Paul
I've heard some awesome Polk Audio in wall subwoofers, that would be a could start, just ensure the enclosure and support are set up correctly.
chudleighpaul
129
pjeast73 said:
Hi all
If you live in a semi or terraced house, dont put it in an adjoining wall, or you will be very unpopular with your neighbour!:wall:
