- Aug 10, 2019
- 2,556
- 5
- 0
Hey People,
i just got a ) Philips 37PFL8404. and have several questions i've been meaning to ask:
1. I currently have a Vivanco Scart 1.5m (http://www.vivanco.de/cgi-bin/vivanco/en_US/productDetail.html?productId=4857&catId=0) connected to my Satellite (SD) reciver.
I sometime switch it to my DVD (LG V190 - VCRDVD).
It's Header is very big and can't fit my cable hole in my shelves.
Is it worth it getting a new one? generally, what's the importance of getting an expensive SCART?
is an analog SCART more important then getting an expensive HDMI (digital)?
- the problems that I face are: availability (major problem where i live) - i am limited to: Monster, tech+link, Hama, vivanco. (Funnily i can get a Van Den Hul - but that costs 158 Pounds!), and price (i am limited to 40-45 pounds).
2. Perhaps i will connect a component cable to my DVD (but the problem with that is i can't watch the VCR with component) - in case i do, what should i get (as i will connect to a an SD DVD)?
3. I plan to connect my PC to the TV, how important is the DVI-HDMI cable (is getting an expensive one worth it)?
it will also require a 3.5mm-3.5mm (2m) cable, what should i get? I currently use my TV speakers only.
4. later i will connect a Satellite HD receiver to the TV, it will be 720p and can get to 1080I, what HDMI cable will be worth it?
A lot of question i know, but I collected them for a while and didn't want to open many topics.
I would greatly appreciate any help! hopefully will be a reference for other users in the future.
Thanks a lot!
Dan.
Thanks a lot!
Dan.
