chebby
fr0g said:No, but personally I can't "prove" that the moon is actually smaller than the sun.
Small ... far away ...
chebby said:fr0g said:No, but personally I can't "prove" that the moon is actually smaller than the sun.
lilneige said:Some people claim an usb power purifier have greater effect on SQ by reduce the noise between the computer and DAC.
altruistic.lemon said:Good to see the warmth of humanity running through your veins, frog.
So you can prove the paul miller review and tests are junk, can you?
davedotco said:lilneige said:Some people claim an usb power purifier have greater effect on SQ by reduce the noise between the computer and DAC.
A competent dac design should be able to cope with that, no problem.
But then, over the years I have heard a fair few dacs that were clearly not competent....... :wall:
busb said:davedotco said:lilneige said:Some people claim an usb power purifier have greater effect on SQ by reduce the noise between the computer and DAC.
Depends Dave what you mean by competent. My M-DAC didn't like my Sony Vaio's USB's output at all if the Sony was powered from the mains. I'd get interference. This was unrelated to the quality of the cable. Other M-DAC owners have solved similar problems with galvanic isolators. Some have found USB 5V splitters have also helped.
I now use USB as the connection for music listening from my Mac Mini in async mode - sounds fab.
