Imac to hifi
Drummerdave
68
Can someone please advise on the best way to stream itunes from my imac to my hifi? I also have an ipad which I would like to use as a remote, and I believe there is a free app that can do this. Do I simply need to buy an airport express and plug it into my amp? Thanks.
I am using an airport express it seems to be the ideal solution when a TV is not involved. If you want the option of audio and visual streaming you should check out the Apple TV.
One day I will get either an iPad, iPod Touch or iPhone for the remote applications.
Veri:If you want the option of audio and visual streaming you should check out the Apple TV.
JohnDuncan:Yes, unless the iMac is close enough to do so.It'll only stream iTunes content though, unless you get Airfoil (which I use for Spotify).
I also use Airfoil with Spotify and now I tend to only use Spotify because it has imported all my iTunes playlists.
When Spotify plays a locally stored track from iTunes it has a 2 second gap 15 seconds into each track, any clues JD?
BTW doesn't happen when Airfoil is set to play 'System Audio'.
Am I correct in thinking that your AVI amp doesn't have an optical input? If that's so, you would do well to get a DAC to handle the optical signal from the Airport Express. The results are so much better than making do with phono.
My V-Dac may not be the last word, but it has made a huge difference and Spotify Premium is much closer to my CD player's sound quality.
Sorreltiger:
I don't believe it does have an optical input. Would a Cambridge Audio Dacmagic be the one to get, or are there better options. Wasn't planning to spend huge amounts.
the dacmagic is great for the money, if i was buying again at around that price though, i would definitely demo the arcam dac. in absolute terms, i found (min filter setting) the treble to have a slight bright edge to it, and the bass to be a little bloated. i thought it was better suited to rock music then, say, conveying the emotion in a delicate vocal.
or you could try something like a beresford, and gain the functionality of a half decent headphone amp.
My V-DAC does sound very nice indeed, with excellent imaging - that was probably the biggest improvement of all. I reasoned that a modest purchase was OK for Spotify listening! Although the V-DAC is a functional little black box, it can be hidden away!
Sorreltiger:My V-DAC does sound very nice indeed, with excellent imaging - that was probably the biggest improvement of all. I reasoned that a modest purchase was OK for Spotify listening! Although the V-DAC is a functional little black box, it can be hidden away!
Thanks for that info - I was wondering if a V-DAC would make a difference to a rather top of the range Yamaha Receiver, given that it already has decent on-board decoding.
Anyway, I have just swapped my airport express for the apple TV. I can't be sure, but I detect a slight deterioration in the audio quality. (nothng else changed, i.e., same optical cable, same input on my receiver). Maybe I need to give it a bit more time.
New Apple TV.
Also another thing- it doesn't extend your network. Example, I could connect my receiver via ethernet to the apple express to listen to net radio, but this does not work with apple TV2. But I could get internet radio via Apple TV2 itself, although this means having to navigate through its menus and I must therefore have my TV on (or I can do it via my ipod touch).
JohnDuncan:Or the Fubar IV, though you lose input flexibility, or the MF V-DAC, though you gain several branches of the ugly tree on the way down.
The Fubar looks like it could be very useful as I don't have a headphone amp. Could my cd player be connected to it as well or do I need something like the Dacmagic or Rdac for extra inputs?
Drummerdave:JohnDuncan:Or the Fubar IV, though you lose input flexibility, or the MF V-DAC, though you gain several branches of the ugly tree on the way down. The Fubar looks like it could be very useful as I don't have a headphone amp. Could my cd player be connected to it as well or do I need something like the Dacmagic or Rdac for extra inputs?
Something like the Beresford Caiman could be an option in that case.
axman:
New Apple TV.
the new apple tv resamples audio to 48khz, apparently.
Are there any other options?
How does it work , i.e. bluetooth, wi fi..??
I am having no luck with a cable connection and want to go wireless anyway, but I don't want to use itunes, neither do I want to have to buy 2 pieces of kit to overcome Its Not Apple soft/hardware.....
