Imac - dac - nad320
Rallye666
6
Hi all, looking to add a dac to my imac to take advantage of my new tidal subscription.
the only problem is my iMac is 10m away from my amplifier.
I could airplay to my apple tv and output from there, but I understand the sound quality wouldn't be as good as wired directly
How would a 48khz AirPlay stream compare to 44.1khz (or higher) sent down a 10m toslink cable?
Is 10m to long for toslink?
Thanks for any help, James
"TOSLINK cables are usually limited to 5 meters in length, with a technical maximum[1] of 10 meters, for reliable transmission without the use of a signal booster or a repeater. However, it is very common for interfaces on newer consumer electronics (satellite receivers and PCs with optical outputs) to easily run over 30 meters on even low-cost (0.82 USD/m 2009) TOSLINK cables."
http://en.wikipedia.org/wiki/TOSLINK
Arguably you won't hear much of a difference, but why not pick up some cheap optical cable and give it a go yourself and compare the two?
The longest I've tried is 5 meters with pretty much the cheapest cable I could find. No problems with it so far.
